front diff bolt failure
Jerry-payne
It's on my 8 , don't you have to drop the subframe to get the transfer box out ?
Jerry-payne
Aw fair enough but it seems to have the same sort of symptoms ?
DsmEvo
DsmEvo
Aruba
hey lee would worn out top mounts have any effect on making random noises on turns?
maybe. as could worn anti roll bar bushes and also make sure the 4 front subframe bolts
DsmEvo
DsmEvo
Aruba
thanks for the info mate.. my car seems to do this like 40% of the time on tight turns but only on half turns.. I once lock the steering on right but didnt hear it.. on rough roads going in a straight I can hear a mild clunck coming from the front drivers side I think thats got to do with top mounts
could also be inner tie rods or track rod ends. you need to check it all before start replacing parts
