newbie evo 8 owner wants upgrades ;)
10.5 hotside is bigger. So it flows more gases. And so increases spool.
Kelford themselves say yes but it's debatable.
Personally I'd fit GSC S1 or Kelford 264 cams if you don't want to do all the other work.
You'll still see 380bhp from all the std parts and a good tune.
It all comes down to personal choice really
andyw08
andyw08
What cams come in mine as standard? And were and how much would i pick a 10.5 hotside up? thanks
Put a wanted add up for the hotside. You can use either a 5/6/tme or an 8mr.
Your std cams are supposedly milder than std 8 cams but....
One bonus you have with a 260 is the thicker stronger rods than std 8's
andyw08
andyw08
Put an ad on here? Were would i do that? Im still getting to grips with these forums ha ha basically this is what i want... cams, hotside, tubeular exhaust manifold, bigger turbo elbow, 3mm lash adjusters, walbro fuel pump, dump valve and a custom remap.. do you think that would be ok and what bhp do you think it would be pushing out? Thank
Around the 400bhp. To much more and your on the point of needing an engine build to forge it.
Tubular manifold, unless your spending loads it's no point. Std is good for 450-500bhp.
Walbro £75
Hotside £50
3mm lash adjusters £80
Remap £200+
andyw08
andyw08
Sounds good......id be happy with 400 :) does the elbow help or is that the same as the manifold?? And were do i post a wanted ad? Thanks for be so helpfull mate
Elbow will give you better response on the throttle
Check in the forsale/wanted section
andyw08
andyw08
Did your mate do the springs with the 272's B6lee? And what other mods did he have?
No I don't think he did. Wasn't required. Did have a new set if valve stem seals fitted though.
3" downpipe back exhaust and de cat
Avcr boost controller 1.70 bar boost
Apexi air filter
Walbro fuel pump
Hks 272 cams with piper pulleys to dial the cams in
Remap :)
andyw08
andyw08
Complete change of subject but how do you thank members??
andyw08
andyw08
Thanks...do you know anyone selling any of the bits i need....10.5 hotside, if i can get away without doin springs 272 cams or 264 if i do, bigger turbo elbow and dump valve?
Keep your eyes peeled. Cams etc do come along. Maybe try the bay :)
