Evo7 Service
N
Nixsonr
Hi All,
Can anyone tell a beginner :confused: how hard it is to do a service and change the AYC fluid yourself??
Also what parts would be required to do a full service because I keep getting conflicting information as to what I will require.
Thanks in advance.
Regards
Richard
5 litres millers crx nt 75/90 will do gearbox, transfer and rear diff
5 Litres Fuchs Titan race 10/40 or 10/50 depending on state of engine tune
2 litres dextron III ATF fluid
1 Mitsi oil filter
Gates cam and balance shaft belts
Tensioner/ idler :)
N
Nixsonr
Evo 7 further details
Hi
Thanks for that. Can you explain what's involved in changing the AYC oil??
I'm a total beginner at this, I have a friend who is mechanically minded but I would still like step by step details for him to follow and for me to understand. If anybody has the time to put this into text I would be very grateful.
Thanks
Richard
K
kobe_1201
U need to make sure it works first. There shud be a step by step here somewhere.
@Lee; hydrolic tensioner ftw? or its unnecessary?
The Ayc bath in the rear diff is easy just drain and refill.
The pump system is a bit more complicated.
Best way to do it is buy the bleed tool that's for sale on here :)
Belt does have a piston type hydraulic tensioner but you can just take it off and put it in a vice an dog it with a small drill bit :)
K
kobe_1201
cheers..
i think i need a step by step on this ... hmmmm
