L
luke sheath
please can you guys read all the following info and have a really good think wheather or not I should keep worrying,
I bought my evo 4 about a month ago, I bought it off a mechanic who was badly in debt and had to let it go, it has.....
*2000 miles on fully rebuilt motor by a specialist
*new thrust bearing and acl big ends
*evo 9 crank rods and pistons
*balance shaft delete kit
*crank and rods balanced
*MR cams whatever they are
*full top end rebuild
*new manual and hydraulic cam belt tensioner
*obviously new cam belt
also evo 8 turbo
about the noise... its a constant whine as soon as the engine fires and it doesn't go away, it rises with the revs, its hard to put into text but its like a zhoooo zhoooooo as you rev, like a tiny supercharger or perhaps a tiny reverse gear sound, its not REALLY loud but is noticeable,
what ive done to investigate.....
taken off the serpentine aux belt and run it, no change at all,
taken off all the cam cover, no change to noise again and it didn't get any louder,
cam belt itself has reasonable slack
I investigated the turbo shaft for play today but that's fine, im SURE the noise isn't turbo related
sometimes it seems like the sound is coming right from underneath the plenum? but im sure nothing under there could make noise,
so what now? I talked to the mechanic who owned the car before me, he said he investigated the cam belt and tensioners, he says its all as new and spot on, he slackened the cam belt slightly just to see, but the noise was still the same so he tightened it again to factory and just lived with the strange whine!
so is that what I do? live with it or keep investigating, only trouble is whats left? apart from that the car runs like a dream and pulls clean and strong, there isn't even any top end, tappet type noise
any suggestions? im wondering if evo motors are just a bit whirrey ?
thanks v much everyone let me know what you all think!
also evo 8 turbo
