Evo 5 idling problems
Ashy
Ashy
Warwick
Right idling problems on my evo now up and down idling and then cuts out tryed a airflow meter that didnt cure it any other ideas ? No fault codes brought up thanks andy
First place is all vacuum pipes and wiring :)
Evo8Frankie
Evo8Frankie
East/North Yorkshire
.Try cleaning the small element in the MAF CAREFULLY with some panel wipe on the end of a cotton bud,
.Or a faulty cam postion sensor??
.Leaving DV/vac/boost pipes
or
I think im right in saying the idle control valve is under the inlet mani and sometimes gets clogged up, and can cause mad idling??? could be wrong i guess its worth a try thou.
Ashy
Ashy
Warwick
Boost pipes
Which one goes where can someone help me
DDS789
DDS789
South Yorkshire
Also when i unplug airflow meter runs like a dream
That is a standard sign that the maf is knackered mate, start there Ie source a new or working one. Did you mean you tried a. New one already?
Don't go on boost when it's unplugged
Ashy
Ashy
Warwick
Airflow meter fine i had clutch done and i think one of boost pipes was connected wrong i wanna know how they all go as i also have a gizmo 3 port solenoid i got it running fine again by swopping pipes over but not sure if they are correct and want too check this thanks
Ashy
Ashy
Warwick
Problem
3 port
port 1 - gauze filter fitting
port 2 - wastegate actuator
port 3 - boost source (turbo housing)
Whats gauze filter fitting where does boost pipe go off top of inlet also thanks and whats the silver thing called by inlet mushroom shape does a boost pipe need too be connected too that the pic where i am holding the pipe i connected that too inlet its hard too explain sorry
Ashy
Ashy
Warwick
More pics
1 is a gauze VTA only, need a few more detailed pics mate
Here are some more pics the solenoid one goes tooactuator then othergies too the other part u said too do with the turbo
