Turbo
DDS789
DDS789
South Yorkshire
I'm fairly certain it will be a 16g
I know the MR has a 16g with 10.5t hot side, yours may be the 9.8t but I'm sure someone will know for sure.
The TD series turbos are good robust units that can take some hammer :D
They are all 16g turbos on an evo 8 regardless of model. Unless it's had a rebuild to accommodate a bigger wheel. You'd only know by a receipt for work or by taking it apart for inspection.
DDS789
DDS789
South Yorkshire
There you go :D
What model differences is it for the 9.8t and 10.5t just had a 9.8t fitted to mine in a rush getting rid and getting another 10.5t hopefully :sneaky:
5-6-tme all run a 10.5
Or
8MR-9 run a 10.5 but single puck flap
konast1n
konast1n
bury st edmunds
Well I've gone and bought a 16g now, has 50,000 miles on it and the owner said it came of his e8 FQ 300, is it worth putting an upgraded exhaust elbow and actuator and will they make any difference
konast1n
konast1n
bury st edmunds
Well I was thinking that the forge actuator is piston instead of diaphragm and has a stinger spring to hold boost better?? Also is it worth changing the exhaust elbow?
It doesn't matter on the actuator unless your running huge boost the actuator will be fine.
Changing exhaust elbow to increase flow always helps. But you could also try porting the one you have!!
It will increase throttle response but not massive bhp gains. Maybe 5hp
I may try the fitting a evo 9 cold side/cover to the race tech turbo I got as that is in an older cover but its had work done to it..
Pull apart the dead fp ;) single flapper ;)
evoaps
evoaps
Wexford Ireland
I want but I think I'd end up with a hole in my block :razz:
Like mine did?
