Evo 4 cutting out
McFall1984
McFall1984
was driving along today an just on boost heard like a whistle then started to struggle with power, cut out, started again an blipped the throttle an sounded like it was off a cylinder, tried to drive on to pull in an stop, stalled just as i got into a wee road
checked all top pipes that i could see an all was ok
only thing i done was change the black rubber pipe that connects the inlet manifold to the dump valve, changed it for a new blue one, same shape an size?
any idea's
Boost pipe somewhere. Need to check from turbo to TB
Evo8Frankie
Evo8Frankie
yeah turbo to throttle body :) and all the other things iv told you mate.
McFall1984
McFall1984
cheers men
i'll get a look when i get it home
@Frankie i posted this on all car forums im on, which is about 12 lol
cheers matey
McFall1984
McFall1984
got the car home, all pipes look good
sounding off a cylinder an black smoke when revved to keep it going
any idea's?
McFall1984
McFall1984
have them out, tips are black, rang a motorfactors, asked for a part number but mine say japan on them? Denso Japan
these wouldn be the ones in her from japan? cars been here from 2007
Evo8Frankie
Evo8Frankie
was they all connected, have you checked o see if there sparking .... and yeah more than likely if there aint any English on them, get some NGK Iriduim plugs
McFall1984
McFall1984
yea they were all good, should i put 3 back in, set 1 on the rocker cover an put the lead close an see what its doin while turnin it over? then do it with the rest an see i 1's at fault?
Evo8Frankie
Evo8Frankie
Yeah thats the one mate.
C
captain slow
Sounds like either the boost pipe to actuator,or a split pipe to the dump valve may be intercooler pipes,doesn't sound much more than that.New spark plugs won't go a miss though. I know you said you'd change one but those blue hoses sometimes arnt the best.
McFall1984
McFall1984
yea i was thinkin of putting the old one goin to the DV back on again to see if that makes any difference
McFall1984
McFall1984
fella's, stuck my hand down the rear of the inlet manifold, driver side an feel a lot of air when being revved
are these common to crack?
