car tries to kill me!!!!!
warrenevo4
warrenevo4
Hey all :) I love my evo4 but it tries to kill me! The problem im having is a little hard to describe but here goes......
It sometimes feels like the rear end wants to go a different direction to the front! If I do say 60/70 mph the rear end starts wondering all over the place. It feels as if bothe rear wheels are loose (have checked) or as if they are somehow steering themselves! Now, im no novice when it comes to cars I used to run my own business restoring classic cars from the ground up so I know my way around a toolbox but this has me puzzled. Ive checked all bushes/ball joints etc and the only problem I found was two very worn track rod ends which have now been replaced.
The trouble is it only does it as and when it feels like it!
Has anyone experienced a similar problem?
If it was down to geometry I would expect it to happen a lot but like I say it only happens one in a while, as if the car has bad moods sometimes and thinks f##k you im gonna throw you off the road lol.
It did have a leaking ayc pipe which has now been sorted, bled and topped up with no fault code coming up anymore but could the ayc system be the cause? Maybe ayc ecu having a fit?
Sorry for the long winded post, if anyone can shed a light on this I would be very grateful.
Billy MR
Billy MR
Rear bushes are knackered or your ayc is ****ed
warrenevo4
warrenevo4
That was my thought too, but as I say there is no movement inthe bushes (poly bushes) and the ayc isnt throwing any codes up :( could or would the ayc system really do it? Its when going in a straight line that it happens so no reason for the ayc to be doing anything. Guess I should pull the fuse and see if it happens again.
warrenevo4
warrenevo4
Hadnt thought of looking for actual cracks, thanks I'll check tomorrow! !
evo arm's m7960
evo arm's m7960
Rear upper control arms are a common fault on 4-6's, I'd check them over for cracks.
this happened to my 4 .
there was a factory recall on these so would be worth any one with a 4 5 6 to call mitsubishi and check if they have been changed or not .
they will change them free , faulty or not so worth a phone call
:0)
warrenevo4
warrenevo4
Thanks v.much for your input evo arms! So I call mitsubishi dealer and they supply new ones? Will they want to see my car to check the arms? Be nice to get new parts even if this isnt the cause of my problems I guess. Im just about to go check my arms over, gets me out of cooking dinner at least!
evo arm's m7960
evo arm's m7960
call them up give them some details , they contact head office then if you qualify then they book u in and change them :0)
one of mine was cracked and knocking and they changed both :0)
