craig201
But if the cat is still fitted dont I need a 260 decat because of the orientation of the flanges? I think it could be a 260 aftermarket down pipe so the cat could be retained cheers
If you have a non cat front pipe sounds like its been replaced with a jdm front pipe, but you still have a cat so i assume its a jdm cat not a 260 cat if you get me
That's what I'm thinking if you don't have the front cat in the down pipe anymore
sorry for this newbie question but coming from a turbo car that didn't need one, i've got to ask.......why do the evo's need boost controllers?
Anything with a Turbo needs a controller. If you intend to change the boost from std factory settings either a standalone controller or ecu remap to suit...
Ok thanks for the replies will take a photo ova the weekend hopefully showing the flanges and cat.:ninja:
this is what im asking rob. my corsa was stage three at 243 bhp and that didn't have a boost controller. so does that mean the ecu was in control? if so why cant the ECU be in control of the evo's boost rather than a boost controller?
and im guessing off that info its the old school evos that require the box inside the car?
Any evo or infact any turbo car has some sort of controller. If you only drive the cars and know nothing about them then you have several choices...
1. Ecu controlled
2. Manual controller/dawes device
3. Standalone electronic controller
4. Actuator controlled only
The last choice is not advised as it is the last chance to control the boost. With the others they work inline with the actuator. So if they fail you resort back to what the actuator is set at.
