Got a mis fire issue with my evo
Deano evo5
Deano evo5
Right went out in the evo today and it was running around 14 psi of boost through a td05 turbo think its off an evo 8 and now every time the car starts to come on boost its like its over boosting and juddering the car some times it boosts ok and then some times it won't ?
If any body can tell me any simple things that would be great there is no smoke or out coming from it and there is no pipes bust so I am baffled by it :confused:
ad-p
ad-p
What's the gap on plugs mate? And what plugs you running?
How are you hitting 1 bar boost. Via a boost controller!?
Deano evo5
Deano evo5
I just have a boost gauge in it I need to invest in a boost controller the spark plugs are ngk iradium I will take the plugs out in the morning and have a look at them the car runs fine its just when its teetering on boost it starts to miss and judder like its over boosting if you feather the throttle it will boost but then when you plant your foot it it just judder s like crazing .
Thanks for the help I appreciate it
dean76
dean76
it sounds like what I had just a week ago I'd change the spark plugs and everything is fine :D
If the boost is still controlled by your std 2 port. It could be failing.
If you have actuator plumbed direct to turbo. It could meen your actuator is failing. Overboost and fuelcut.
Or as said could be failed plugs. Just replace with std brp8es plugs gapped at 0.55. £10-12 a set
Deano evo5
Deano evo5
Thanks guys for this it means a lot I will get some new plugs ASAP for it thanks for the advice I will look into every thing you have told me cheers
DDS789
DDS789
I had this and it turned out I'd got np bad connections on my spark plugs :shock: the plugs onto the spark plugs had worked loose! Just get under there and check the connections are all good and clean
An easy start
:D
Deano evo5
Deano evo5
I think this might be my miss fire problem
Think it needs setting up on the rollers this is coursed by an under fuelling issue if I am correct ?
Nath-t
Nath-t
Ngk I paid about 12 quid a set lol and run them on 2.2 bar ;-)
Deano evo5
Deano evo5
Got the plugs I got 8 just in case it happens again put the new ones in and its running mint but I still need to get the problem sorted with the under fuelling issue don't want to melt a piston I can cope with a plug or 2 but don't want an engine rebuild
