Throttle body mod?
DDS789
DDS789
Ps your ramblings are all taken, I'd never dismiss anything I'm here to learn :D
raph
Maf has intake temp
and the earlier evos have a fast idle valve that's filled with a wax that reacts to temp..I opened up my dsm tb and looked inside,the waxy like material makes the bypass bores open up or close due to temps .. and yes it had the same idle stepper.
If I find it in the shed I can post up pics.
raph
Aww the dsm vfaqs page is running on the wayback when machine,there was a beatiful Isc and BISS explanatoin..all 4g63 specific.
In a nutshell all the diagrams are gone :(
DDS789
DDS789
Maf has intake temp
Would be interested as in my opinion anything beyond the mad sensor is irrelevant to what we've talked of.
Surely for the ecu to make adjustments it would need to be after the TB???
The coolant going through the tb is there to stop it from freezing in extreme conditions, that's all, personally I would leave it connected as this country sees a lot of moisture and sub zero temperatures and I don't think there's any benefits from disconnecting it, as for idle it won't be effected at all, connected or disconnected
In this climate I don't think your going to miss it, if you do decide to get rid
DDS789
DDS789
If I'm ever under there again doing something else I'll delete it. Not going of take it all apart just to do it lol.
