might off encountered my first evo problem
mart1983
mart1983
hertofrdshire
well,
on saturday morning i thought i would check oil and water as you do for the first time and i noticed there was no coolant in the header tank,so i topped it up and went about my business for the day, drove about 50miles max and sat in a little bit of traffic on the a10 for about 10mins. anyways when i got up sunday morning i thought i would check again and the was about 2/3 of the collant gone from the header tank..:confused:.so i topped it up again and went out and done about 20-30miles drive.. i got back and the level went up a little,so now i am thinking head gasket failed! :shock:. i got up today and the coolant level is just under the the full mark and the over flow pipe is bone dry,i mean it has dust in it so i cant see if any coolant has gone, i know if its blowing gases into the collant system it would push all the coolant out through the over flow pipe on the header tank (i think):confused:. i have taken the cap off the radiator when doing all this and its always been full with coolant! thinking of getting a sniffer test or a health check, but aint got a clue where to take it around my way (hertfordshire)
anyone got any views on this or should i just bare with it and see what happens and if the coolant disappears again..:confused:
X
xiii
Whats level like in the radiator as ive heard theyr just an overflow tank and never have much in. Dont know how true that is though.
X
xiii
Best off doing an oil change then you will know what oil is in it. Use a 5w40 fully synthetic like motul, fuchs or millers
mart1983
mart1983
hertofrdshire
so, am i not meant to put coolant in it? :confused:
getting mixed massages here! is the plastic tank just for over flow or should it have coolant in it! as the radiator is full!
X
xiii
Im not 100percent on it either. Read over the road on a thread that it was just overflow. I just keep an eye on level n mines not moved so havent touched it.
craig@dd
craig@dd
sheffield
the plastic tank will fill up when the engine is warm and empty when the engine is cool, make sure the rad is full of water and then put a bit in the bottom of plastic tank and keep a eye on the rad when its cool if it remains full when it has been warm and cooled down there should be nowt wrong
mart1983
mart1983
hertofrdshire
cheers craig :)
