Cheers for the imput guys, I've been sat in the bath pondering and come to the conclusion that;
A)
the crankshaft cannot be 360 out as thats one full turn putting everything back where it was in the first place, if it was 180 out then it would be trying to fire on the induction stroke so wouldn't run at all. B) the lefthand balance belt must surely be aligned as it makes the same amount of rotations as the crank and those timing marks I'm positive lined up correctly and was tensioned to give the 5-7mm deflection stated in the manual.
Therefore it must be the right hand balance shaft a tooth or half a tooth out. I was struggling over the pit trying to hold the exhaust cam in position while holding the belt on at the same time as trying to feed the belt round the idler, oil pump sprocket and crankshaft so it surely must be my problem.
Better get my screwdriver out tomorrow
