1982ollie
Hi Guys,
Just a quick question for you all. I have put my standard re circ valve back on my car, from my HKS SSQV V.T.A, because it wasn't running perfect due to the idle set up. So I'm going to hang on to it until i get a re-map, with a 6 ecu or I'm going to Mark Shead @ Mad-Developments for a full stage 1.
Now the question is - I have heard that you can put your standard re circ valves on back to front to stop the waste gate chatter sound - Now I have done this and it doesn't make the waste gate chatter noise any more, it almost sounds like a little quiet whoosh when your going slow and the car is idleing perfect.
Is it ok to do this or is it going to put more ware on the turbo or do anything to the engine that could be harmful?
Cheers Guys,
Cheers Guys,
