Modding my evo9 mr
Dinarte evo9
Dinarte evo9
Hey guys new to the forum and not really sure if this is the ryt place but here goes I have an Evo 9mr that I'm gonna be doing the following mods on. The tuner says I can expect 650bhp with this setup, wanted your guys take on it. Of sure what boost the tuner is planning on running etc.
All advise would be great.
AMS V-band turbo kit : Precision 58/58 turbo ( kit
includes : tial wastegate, exhaust manifold, 3" downpipe,
12" low profile electric fan, all oil & water lines ) 1 AMS intercooler 1 AMS upper intercooler pipes ( need to move battery to
boot ) 1 AMS lower intercooler pipes 1 Labour : move battery to boot (needed when installing
AMS FMIC) 1 Wiring and fittings for battery in boot 1 Syvecs ECU ( full replacement incl loom adapter ) .
Controls everything from fueling, timing, AVCS to boost.
Also has launch control 1 Aeromotive fuel pump kit 1 Fuel surge tank, Goodridge braided hoses & fittings 1 Weldon external fuel pump 1 Labour : fit surge tank, fuel lines and pump 1 Mapping of ECU 1 800cc injectors ( set of 4 ) 1 HKS fuel rail 1
HKS fuel pressure regulator & Goodridge hoses & fittings 1 HKS oil cooler kit 1 Labour : oil cooler 1 HKS spark plugs 4 Labour : intercooler, boost controller, regulator, injectors, turbo kit, plugs, fuel pump, fuel rail 1 Exedy twin plate clutch kit 1 Labour : fit clutch 1 Redline gearbox oil 4 Redline diff oil 2 HKS Silent Hipower exhaust 1 ARP head studs 1 AMS 2.3 stroker kit ( JE pistons, Manley I-beam rods, Manley crankshaft, AMC Race balance shaft eliminator
kit ) 1 GSC Zero tick lifters 1 HKS head gasket kit 1 Labour : remove & refit engine 1 Oil & filter 1 Consumables 1 Antifreeze 1 HKS timing belt 1 HKS crankshaft pulley belt 1 HKS camshaft (IN) 272, 10.8 1 HKS camshaft (EX), 278, 11 1 HKS camgear 2 GSC titanium beehive spring upgrade 1 Labour : fit camshafts & valve springs & cam gears &
rebuild motor 1 Ferrea 1mm intake valves 8 Ferrea 1mm exhaust valves 8 Engineering : fit valves and springs
Dinarte evo9
Dinarte evo9
Sorry bout all the labour added on lol I just copied an pasted off the proformer invoice.
Thanks guys
Sounds about right to me, but you will be needing a 5 speed box eventually.
Dinarte evo9
Dinarte evo9
Thanks for the reply. And what boost do u think ill be hitting to get that power?
And 1-4 mile times?
Dinarte evo9
Dinarte evo9
That's what my tuner
says I'm sending the at in on Monday. Will injectors alone make me be able to get more power on this setup?
Didn't notice the injectors, 800cc injectors won't be able to flow enough fuel you need 1000's
Dinarte evo9
Dinarte evo9
But would injectors help me get more power with the setup?
Will stop it leaning out and destroying itself, 1000's as said would be a must for that power.
That and some deep pockets lol
