Power steering fluid
mikeyb1983
I have power steering pissing out of the bottom of the hose connected to the upper part of pump that goes to the rack any ideas whether there is a seal that can be replaced or the whole hose or if it is the pump itself.....it's coming from bottom part of pipe in pic
Wingnut247
Wingnut247
There is a crush washer under the hose fitting, an 2 different sized o-rings on the pump were the hose goes! Got same issue, replaced all of the above but still dripping from somewhere most annoying! Hope this helps!
yea i thought youd see this :)
mikeyb1983
Thanks will try this.... Anything special I should remember when removing this or refilling the system???
just do it quick and hold the pipe upright so fluid dont leak out. then re conect and pump will sort itself out :)
mikeyb1983
do you know the part numbers at all??? what if the pump has pissed all the power steering fluid out?? what do i need to do??
need some quick hands not to lose much fluid :razz: or slip the bottom washed in and out with the banjo still over the hole lol..
as said looks like one of the washers have gone
mikeyb1983
Any one know sizes of seals and washer or even part numbers......??
invisible
invisible
Also if you need to refill make sure to remove any 'trapped' air in the system.
So just to be sure, leave the cap off the power steering resoviour and do a few turn on the steering wheel full lock in each direction, then replace the cap - should sort it.
Good luck.
PS. I think its most likely to be a washer of some sort rather than the pump itself.
What Evo you got - i may have the partnos for 9 somewhere in my bible!
mikeyb1983
i have a V and i will have to refill i know it, what grade fluid do i need??
mikeyb1983
Wanted new pipe
Nope it is actually the pipe......does anyone have one laying around....please!?
