recirc hose causing boost problems?
B
bandit
would a small hole and worn/perished recirc hose have much affect on how my car boosts? the reason im asking is im sure it hasnt been boosting quite right for a while now.ive checked all other boost and vac hoses i can think of but have noticed the very small hole in the recirc hose! boost seems to be a bit ify but does boost to about 1 bar! and ive been getting a strange kinda metallic type almost induction noise,thought it was the turbo but i can hear that spooling aswell and no smoke etc and is still boosting to 1 bar just sometimes seems a little flat at times,just the noise has baffled me!:confused:
Any hose with a hole in it or just leaking will cause problems
B
bandit
Thanks mate.im trying to find a replacement hose now.any ideas on the metallic rattle type noise im getting when on boost?would this be a hose causing that type of noise or would it be the turbo on its way maybe? Thanks.
I would say turbo. Take intake pipe off and check for play on the shaft
B
bandit
this is what i was guessing but wasnt sure,but if it is the turbo then would it not boost at all?,as im still getting full boost most of the time just sometimes seems flat etc not had any smoke etc either but does make sense with your answer:sad:
It will still boost, right up to the point the guts it the turbo give up completely and get sucked through your intake and into your engine. Give it a quick check only takes a couple minutes :)
B
bandit
how do i check it exactly mate?which hose etc needs coming off? thanks:blush:
The big one on the front of the turbo. Take it of and just check for any excess shaft play. If the compressor wheel blades touch the sides then that's your problem
B
bandit
thanks mate will have a look 2moro if i get time.it does sound like a turbo problem to me.would it be best to just get a 456 replacement if so and is it a easy enuf/quick job also? dont want to spend too much if possible as im looking at buying an evo 8/9 soon:)thanks.
B
bandit
Right ive checked my turbo today.the shaft hardly moves only a millimetre or so!when i spin it with my finger it makes the slight noise ive been hearing!so not sure what to do now.is it just a noisy turbo or does it need replacing?its been like it for a while now.thanks.
movement in and out or side to side??
if its making the noise when you turn by hand then its knackered !!
B
bandit
Side to side very slightly!,and makes the slight rattle noise when turned with finger.thanks.
