Thought i would attack the Evo's arches with autumn setting in, so im going to concentrate on each one indivually starting with the rear drivers side.
Jet washed it out then scrubbed it thoroughly before another jet wash before allowing to dry, a little bit of surface rust had gathered but nothing bad at all, used a wire brush drill attachment to clean the rust off before treating the metal then spreying on some undersealing treatment paint then a few coats of undersealer
Progress so far, going to let the arches dry over night before applying the undersealer.
Common problem for the metal fuel pipe to corrode and thus leaking my V power onto the floor
so have fitted a new jobbie and undersealed it to death!
Undersealer applied to arches plus the primer allowing to dry
Hopefully attacking the clutch this weeked weather permiting ect also plan to fit new disks and pads all round and poss some coil overs too.
Been speaking to Rimstyle today where i got my Comps for the GT about a set of 9.5 x 18 Rota Grid drfits just deciding on a relervant tyre to compliment them.
