Phil74
Removed my E5 Engine, Gearbox & Transfer Box today and have the engine now split. Had the engine. gearbox & transfer box removed in over 4 hours, just me and my wee girl removed it. This is the quickest way of removing an engine more or less by yourself.
Drain all oils from engine, gearbox and transfer box.
Drain the water from your radiator.
Unclip, undo, remove all pipes, electrics, fuel hoses and gear linkages.
Remove exhaust from the downpipe to the end of the decat.
Remove bolts from the prop shaft and undo hanger bolts and drop the prop shaft out of the transfer box.
Remove north/south bar
Undo track control arms, remove front drive shafts, front drop links.
Take the weight of the engine and box on an engine dolly and lower the lift.
Undo engine and gearbox mounts and car the lift making sure nothing has been still attched.
Engine, gearbox and transfer box now removed.
