Air leak
m7gsr
As title, took car out for a drive and got an air leak around when 3k revs. Leaks around when turbo kicks in. Just about got it home, luckily round the corner when it happened.
I'm guessing boost pipes split. Noticed it wasn't as quick the last time I drove it!!
Had a day off, took for drive and this! Sods law, back to work tomorrow so can't get it sorted till Saturday :(
Any suggestions what it could be? Could it be actuator playing' up too with the power loss?
Power loss because you have an air leak... A leaking system will reduce power. Find the leak and solve your power loss aswell :)
m7gsr
Thought they might be linked, was no air leak to start off with but power was down quite a lot. I'd say easy 40hp!!
Cheers Rob
Will try and get a look tomorrow. Just started hammering it down outside. There's the end of our summer! lol
Boost leak common on all turbo cars, check all couplings, have you got a boost gauge
m7gsr
No Boost gauge In this one I'm afraid Craig. I'll have a check, might have one somewhere
You will get the nack of searching for boost leaks mate, a common problem one is te one that goes from tubby to cooler
m7gsr
Tell me about it mate. I reckon could be the one. Can hear a lot of air being sucked in and car wouldn't/couldn't really rev past 3k. Revved fine when stationary!
m7gsr
Update
It's the bloody inlet manifold! GRRRRRRR
Should be sorted tomorrow though :)
What's wrong with it? Cracked? Or pipe come loose
m7gsr
I seriously need to get my hearing checked!! lol
Problem is a cracked pipe that connects to boost pipe which connects to the manifold :)
