Metal pipes coming from manifold
T
tom01793
Hi all what the is metal pipes comeing from the top of my manifold on an E4,
Is it some thing to do with exhaust recycle ect is it need as an old e4 i had in the past it wasent there?
dan2926
dan2926
egr pipes to the egr valve mate. your last one must have had egr deleted (Common mod)
T
tom01793
So can i just blank them off then at the point were they meet the egr system just put a blanking gasket in, will this effect the car in anyway in a bad way?
dan2926
dan2926
Pretty sure you can just do that but i would ask or search the forums. I havent done it personally so couldnty say for definate.
T
tom01793
cool i think you can as well i hope some one will respond on here then
The metal pipes going to the exhaust manifold are SAS not egr. Secondary Air System... used for cooling the turbo and assists in the pops/bangs.
It can be removed and blanked off at the manifold and air intake.
EGR .. Exhaust gas recirculation
SAS .. Secondary air system
The 7 has both, all others have SAS only
T
tom01793
Got it now
On the Mitsubishi Evolution later series (evo 4-9, JDM models only) the SAS (Secondary Air System) can be activated to provide Antilag.
So in that case why would anyone want to remove this?
I'd rather have a full awareness of what my car does at all times :)
dan2926
dan2926
True m8 i like to know too tbh i had never heard of sas and only "egr delete mod". I just meant if i dont know anythin about somethin i wont touch it and it will get a trip to the garage lol i have tried looking for info about sas but cant find anythin :confused:
Will2
Will2
yep ! vii has both indeed .....had to re install SAS pipes while back when i fancied some noise ! also blanked off egr valve to aid with the pops n bangs ....sod emissions,the trees doth grow still
What do you want to know about the SAS??
You can leave it on and have it help with pops/bangs and cooling of the turbo.
Or
You can remove it.
T
tom01793
So if removed the sas that is will u get more pops and bangs or the other way round
