Hi all,
if the answer to the title is yes then just let us know what you are after right here and some one will be along in a while to help you out.
We have quite a few specialists in this field that are active members and they will be happy to point you in the right direction whether it is advice, supply or re-mapping that you require.
I personally vouch for the following:
Russ/Cossie1:
GEEK MAPPER/TECH specialist He Can travel to you to map your car!!!
Jamie@evotune:
Mapper/TECH specialist
John@evobreakers:
ECU and general parts supplier
Sponners:
Supplier of both Standard and pre mapped ECU's
Just post your requirements and leave the rest to them!!!
It could not be any simpler I think
Russ/Cossie1:
Jamie@evotune:
John@evobreakers:
Sponners:
