P
Pompeycookie
Anyone know which actual value of resistor works to bypass the pre-tensioners and get the dreaded SRS light to go out?
Putting a multimeter on the removed unit gives a reading of 2.4 ohms and I have 0.2 ohmn test leads so in theory 2.2 should be right.
I have had to cut the plug off too because as soon as you disconnect it from the pre-tensioner unit the pins go to short circuit. Just be good to hear from someone who has actually done it, I can just see me mucking about with resistors all day long!!
