Wheels rubbing arches help
B
bakes fq
Bedfont Middlesex / near heathrow
Hi , iv notices that the tires on the rear are hitting and rubbing on the lip of the arches when ever a go round a sharp bend or hit abit of a dip in the rd . Has any1 had this problem on there 9 and is it a simple fix ? Many thanx
m7gsr
West Yorkshire
I've got the same size tyres on my 9 and seems ok, but sayin' that, mine isn't lowered. Could be because of the offset!
m7gsr
West Yorkshire
Shouldn't be too difficult. Personally I'd get someone to do is due to the panels being pretty light. You wouldn't want to get any dents on it
Moray, 57N
There is a solution!
Depending how good some engineering companies are around you, they can mill down the face to increase the offset, the issue you have is the wheel sticks out way too much for the rear arch, even if you went for a shallow tire - ie 255/35/18 you'd still rub, you need to bring the wheel back in.
Here's a few places
Heathrow Business Directory - Machining
The other extreme option is to try and roll your arches, but i'll advise you that its hit and miss whether its successful.
oakie1
hi there i had the same on my evo 4 lowerd.so i had my arches rolled and put 225/35/18 on in stead off 40s that helped me
B
bakes fq
Think I mite have to get them rolled and see how it hoes from there .. Thanx for all the help again ... As fun as it is to mod cars it sure does break you when u come across problems ..
Take the wheels back cos clearly they sold you the wrong offset !
raph
On the couch/ Germany
rolling the arches on any car older than 6 months may require paintwork afterwords.. id budget 80-150 pounds of "spot repair" to rectify the paint incase it cracks etc..
Good luck with that !
Heard lots of times about paint cracking so be extra careful :)
