Do I short out pin 1and4 to get sensor codes or just pin 1 need to find out if its cam position sensor or crank angle sensor and what to use to short it out?
Are the pins numbered if not how can a find what ones to short
Pins arnt numbered but as you look at it you will see there isn't a metal contact in each, so it's actually 1st and 4the metal contact. This is how I flashed the ayc fault I think it's the same for others
