Turbo timer settings? ( blitz )
McFall1984
McFall1984
Co. Tyrone
here goes
bought a blitz FATT turbo timer for the evo 4
fitted an all was well
when i turned off the ignition the timer counted down an it was great
then 1 day i wondered what all the other settings done an made a balls of it
now when i turn the key it shuts off
its the silver box type timer, not the little dongle sized ones
anyone help me get it set up right again?
if its anything like the HKS there is two timer settings and a volt gauge, you can just adjust the timers with the up or down button in incs of 30seconds.
ok bit basic but is the timer turned on? :p if it is and its not working you can reset the device.
McFall1984
McFall1984
Co. Tyrone
the 1 i have the the silver square timer
its on an all wires connected
it did work but then i had a play with the settings an messed it up
removed the battery terminal there for 30 mins an it reset itself but not shutting off with the timer, just the key
