temperamental ayc light
GG205rob
GG205rob
Somerset
I got my evo 4 gsr a few months age and the ayc light wasn't on, i soon realised that it didn't come on with the ignition so put a bulb in where someone had removed it and suprise suprise, the light came on every time i drove it. This stayed the same for the last 2 months untill yesterday, i did about 20 miles in three different trips and the light didn't come on, the car also felt different when cornering quickly, on the way to work this morning the light didn't come on but did on the way home. Is there anything i can check that would make the ayc work occasionaly but be faulty most of the time?
Cheers for any advice
Fault code is 42 when the light is on
m7gsr
West Yorkshire
these are the codes
96 -00 mitsi eng codes
11 Oxygen sensor fault.
12 Airflow sensor fault.
13 Intake air temp sensor fault.
14 Throttle position sensor (TPS) fault.
15 Idle speed control (ISC) motor position sensor fault.
21 Coolant temp sensor fault.
22 Crankshaft position sensor fault.
23 Camshaft position sensor fault.
24 Vehicle speed sensor fault.
25 Barometric (BARO) pressure sensor fault.
31 Knock sensor fault.
32 MAP sensor faulty.
36 Ignition timing adjustment signal fault.
39 Oxygen (O2) sensor fault.
41 Injector(s) fault
42 Fuel pump fault.
43 EGR fault.
44 Ignition coil (cylinders #1 & #4) fault.
52 Ignition coil (cylinders #2 & #5) fault.
53 Ignition coil (cylinders #3 & #6) fault.
55 Idle air control (IAC) valve position sensor fault.
ABS codes
11 Wheel speed sensor (FR) system (open- or short-circuit) 35B-8
12 Wheel speed sensor (FL) system (open- or short-circuit) 35B-8
13 Wheel speed sensor (RR) system (open- or short-circuit) 35B-8
14 Wheel speed sensor (RL) system (open- or short-circuit) 35B-8
15 Wheel speed sensor system (abnormal output signal) 35B-9
16 ABS-ECU power supply system (abnormal voltage drop or rise) 35B-11
21 Wheel speed sensor (FR) system 35B-8
22 Wheel speed sensor (FL) system 35B-8
23 Wheel speed sensor (RR) system 35B-8
24 Wheel speed sensor (RL) system 35B-8
32 Acceleration sensor (longitual acceleration) circuit system 35B-13
33 Stop lamp switch system (open circuit or stop lamp stays ON) 35B-15
41 Solenoid valve (FR) system 35B-15
42 Solenoid valve (FL) system 35B-15
43 Solenoid valve (RR) system 35B-15
44 Solenoid valve (RL) system 35B-15
51 Valve relay system 35B-17
53 Motor relay system 35B-19
63 ABS-ECU failure Replace ABS-ECU.
71 Acceleration sensor (lateral acceleration) system 35B-20
ayc etc
12 power supply open or short circuit
21 fr right wheel speed sensor open or short circuit
22 fr left wheel speed sensor open or short circuit
23 rear right wheel speed sensor open or short circuit
24 rear left wheel speed sensor open or short circuit
25 wrong diam tyre
26 faulty wheel speed sensor
31 steer sensor system(st1,st2,stn)open circuit
32 steer sensor stn short circuit
33 steer sensor stn system
34 steer system st1 st2 short circuit
41 tps open or short circuit
51 longitudinal acc sensor open or short circuit
52 longitudinal acc sensor
56 lateral acc sensor open or short circuit
61 stop lamp switch system open-circuit
65 abs monitor system open or short circuit
71 proportioning valve system open or short circuit
72 directional control valve right open or short circuit
73 directional control valve left open or short circuit
81 ayc relay system open or short circuit
82 electric pump system
83 electric pump system13 - Fail-safe relay system fault
81 - Pump relay open or short circuit
82 - Pump malfunction or sensor failure
Code 84 should reset itself upon switching off/on the ignition
Yea I'd reset the code then read it again :)
HermaN
HermaN
Aberdeenshire
Time for a new pump then! Well, either that or the pressure switch has failed, which does happen.
GG205rob
GG205rob
Somerset
Thats what i thought before. I didnt know if there could be a reason it now sometimes doesnt come on when it always has until now?
robotech
please could you tell how to get code by ayc lamp flashing. what should i do? thank you
