Well I got in the car this morning and the lights didn't come on after been in the garage all night but came on on the way home from work,the prob only came back since the cold weather so I asked opie oils about the oil just to check and it turns out id been given the wrong oil,he said to go for an atf fluid,something like fuchs atf 4400,I've had a look at this and it says its a auto transmision fluid for jap cars,so just to double check I rang mitsi garage again,now there sayin something else,he said its an oil called diaqueen(think that's how its spelt)at £15.40 per litre,then said I can't just change the oil,it needs to be bled through the system properly by a machine that hooks up to the pump and ecu,they charge £60 plus vat for the privallage,what a joke,so in reply I said,firstly I've spoken to a guy at opie oils and there is another oil that can be used,and secondly how can they justify over 60 quid for a simple change,and if I need them to use the machine how come we managed to bleed it last time ok ourselves and why didn't they mention the machine two month ago,which he replied they should have told you and that I havnt bled it properly.haha what a div : )
