The car feels way slower now. The bov is used and is branded 'forge'. Can this happen?
Waffle Member Messages 59 Location Cork, ireland Aug 19, 2014 #1 The car feels way slower now. The bov is used and is branded 'forge'. Can this happen?
Evomad4 Member Messages 178 Location Stoke-On-Trent Aug 19, 2014 #2 dump valve could be leaking under load. so instead of the dv staying shut it could be slightly open due to the spring being to weak
DDS789 Well-Known Member Messages 1,430 Location South Yorkshire Aug 19, 2014 #3 As evomad4 has said Or some form of boost leak. The easiest way to test is to take the DV off block the holes and the vacuum pipe and take for a spin if all power is back then the DV is to blame. What car was the DV off?
Billy MR Well-Known Member Messages 2,630 Location Norwich Aug 20, 2014 #4 Also some dump valves needs mapping to the car
