Revs dropping and car nearly stalling!
Samj
Oxfordshire
Hi all - I hope you're all well?
I've owned my Evo 4 GSR for around 2 weeks now, and have noticed a funny problem!
Sometimes when I rev it high or when I depress the clutch when coming to a stop, the revs drop really low and sound the car is going to stall! It has actually stalled on 2 or 3 occasions and then starts again straight away.
Does anyone know what this could be?
Thanks in advance for your help; I look forward to your replies!
D
DennisEvo
i had the same problem after i put a bov on,it was one of the turbo smart ones so i could tighten and loosen it,after an hour or two of trial and error i got it set right,just needed tightening a bit more. hope that helps
evoross
perth
;)Has car got performance filter on,if so check your MAF sensor ,on air inlet pipe, for dirt or oil on sensor, quick squirt with carb cleaner should sort it, if not see if you can borrow a maf to try out as i expect they are quite expensive considering there's nothing to it,hope this helps:)
sgbarker31
Watford, Herts
Hi, my Evo 5 does this every now and again.... Not like its when I do something special either, just pull up at the lights or something and put my foot on the clutch.
Im running a Bailey vent to air BOV. Not sure if this is causing it, as i was running the same setup on a different Evo with no probs at all?
Let me know if you figure it out.
Steve
evo4life
mansfield
mine dose this sometimes the revs drop to under 1k ther up to 1.5k then back down (repeats a few times) then if i dip the cluch or rev it a little it fine again
D
dode1
turriff aberdeenshire
revs dropping
could be the throttle body is needing a clean with carb cleaner or the tps is faulty (throttle position sensor) its on the bulkhead side of the throttle body
regards
stroker kid
stroker kid
its a common proplem wit 4s it has ta do wit the air flow meter wit a induction kit or dumpvalve in the car wen comin down in revs it floods it self. i put a hks idle control stapiliser in my 4 and it did the job drops straight bk down 2 idle wit no props
