power loss hissing noise
mr.jiggs
Hi my 8mrfq300 making hissing noise and no powrr help please???
Billy MR
Billy MR
Check boost pipes and all inter cooler joins for splits or being loose
Do you have a dump valve it may be stick open
roynx79
roynx79
+1 check all boost pipes and check your dump valve isnt stuck open
Wingnut247
Wingnut247
+3 also check all small vacuumed lines on inlet manifold,
FQ NICK
FQ NICK
Also check the bottom of the sas valve hasn't broken off.
N/s of engine around the cam sensor area.
mr.jiggs
Problem analised its my dump valve flap wont close?? Shall i take it off the car snd take it apart or can i closr the flsp while its on the car???
Lol craig just checked no cobras in dash
Ah phew I was worried for you just in case it came out.
If its wedges open your best pulling it off and apart and find out why, if its cream crackers you can blank off the pipes for now and grab a new one
mr.jiggs
Tnks lads all done took the dump valve off greased it up and put it together it sounds a treat now
