Parts for brembo conversion
Never mind buddy, you lost and you gained so at least the preparation will be in order for the job.
RSmark
RSmark
Brembo/Hel and OMP Brake conversion got fitted today. HKS SPF Airfilter fitted aswell.
All started off well, until the genuine Mitsubishi Bolts had to be fitted....bit stupid but you need a washer on each bolt which all conversions i read had failed to mentioned.
had everything bolted on and bled each caliper. then pumped the brake pedal and tried to move the car. Turns out it wouldn't due to above reason.
Either way a good day and a good result.
