oil dipstick
MR.LANCER
MR.LANCER
Birmingham
last night after racing my mates sti, having a total of 7 runs my 4 started smoking!
popped the hood & saw the oil dipstick out.
it was pissing out oil on to the exhaust which was letting of some serious smoke.
it was a very well foggy evening for my mates sti, as i left him 3 cars every run with a weak clutch lol
i have topped up 3 litres of oil to the mark & got the engine steam washed.
its running fine, with smoke cleared.
the dipstick is not so firm when in postion.
could it be i was hammering the daylights out of it as i was told by someone that this issue is common on the 4's
quakes
quakes
wolverhampton
hi m8 i had the same prob just get a pair mole grips and just pinch the dipstick housing with the dipstick in ay done it since
MR.LANCER
MR.LANCER
Birmingham
i have put a thicker seal on it so its firm in the housing.
hope it dont happen again.
its a nasty mess.
I spotted you this morning at around 11:30 am on Medlicott Road. It seemed to be running all right!!!
You want to crimp the dip stick housing very slightly to ensure it does not happen again.
It is common on the Evo's and only occurs when driven extra hard. Usually it triggers the check engine light too.
The way you are driving, I would not be surprised if the Dif pops on you. Try and source one so you know where to go when the inevitable happens.
MR.LANCER
MR.LANCER
Birmingham
yup thats me El'
10 ish must have been as i was going to work.
im around the corner from you guys up in highgate.
got the lucas thick oil in the diff for time being.
im a v-tec man but the good old jap turbos are great!
Mmmmmmmmmmmm..........
Lucas Stabiliser!!!!
Very good oil, turns all the knocks into tickles!!!!
Dave Brennun
Dave Brennun
Birmingham
crimping the dip stick hosing is a good trick, i have done it lots of times to various evos i had over the years.
fingers
fingers
east sussex
that what happened to mine just after i blew the engine!!!!!!!!!!!!!!!!!!!!!!!
Dave Brennun
Dave Brennun
Birmingham
actually fingers.....................it's probably what happened BEFORE you blew your engine and might even be WHY you blew it:confused:
are you back on road yet?
a temp sensor is a good idea if your the kind of driver i am. looks after your head gasket so aint a bad thing. oil pressure sensor is a MUST either way.
Dave,
I am sure that the car has an oil pressure sensor buddy, perhaps you are referring to an oil pressure gauge here???
