Oil change guide
Nick
Nick
Superstar Admin
North Yorkshire
A quick guide to an easy oil change!
  1. Start the car and run for 10 mins at idle.
  2. Undo the sump nut (17mm off the top of my head)
  3. Drain oil. (make sure you have enough space for 7L of oil - there isnt 7L but it gives some room to not spill ;) )
  4. Once oil is drained remove filter by unscrewing counter clockwise. Tip: screwdrives stuck through can help if its very tight and you dont have the proper tools (which are a couple of quid so buy one!). Be prepaird for oil to dribble out of here.
  5. Fill new filter with new oil.
  6. Put the new filter in remembering to put a film of oil on the rubber seal on the oil filter to ensure it seals. Remember tights tight and bust is fooked.
  7. Clean sump plug. Replace (often a good idea to use a new copper washer too) and again dont over tighten!
  8. Fill with oil to dipstick indicated level.
  9. Run car and check for leaks.
  10. Check and top up (oil always finds hidey holes)
C
Coyote
Near Southampton UK
Hi - I find it easier to remove the drivers side front wheel when doing an oil change. You then have the sump plug and filter right in front of you instead of having to get under the car.
Sunny Cornwall / UK
If you guys ever need any help with oil related matters, please contact us and we'll do what we can to help.
Tom C
Tom C
Essex
What oil-filters do you guys use/recommend? ive seen very cheap ones on ebay but want quality lol
cheers
btw its for a IV :)
Tom C
Tom C
Essex
Arrived yesterday, and fitted today :cool:
Gotta say it has been the easiest oil/filter change ive ever done on a motor and ive owned/ Fords/Vauxhalls/Renaults/BMWs etc
Easy access to sump plug and Filter :cool: gotta love Evos :D
4
4AGE666
essex
i did oil change once by myself,but never know where to throw oil away?:D
