Have you tried looking to see if a fuse has gone?
the ABS codes its bringing up mean something mate. Long flashes are the first digit i.e 4 long flashes is 4, short flashes is the next number, i.e 4 short= code 44
That would say error code 46 you are seeing above, not sure on that one without seeing the car.
If you disconnect the battery for about 5 minutes it clears the error codes. When i had a faulty crank sensor the error code was intermittent, was a tough one to find, tell me have you changed your belts recently?
Matthew
Good job on finding it mate that would have cost u a fortune at a garage and a hell of a lot longer
how lucky where you :O)
well some one is watching over you now buddy :O)
good luck with the new sensor ;O)
