mikey.watters.5
Hi there new to this but I have a problem with my evo 5.
I have no fuel at cylinders 3 and 4. I have checked voltage to the injectors it's good. Same at all 4 connectors. All injectors are good, have been swapped and checked. If I use a test lamp on crank it flashes on cylinders 1 and 2. I have checked writing back to the ecu and everything is ok continuity and resistance. I believed it was the ecu not switching the earth but have since replace it but I have the same problem. Checked the ecu earths too. It's driving me insane and would be very greatfull for a fresh insight or any help at all??? Thanks
