New from Norfolk and need some help
evobex
Hi All,
I'm Beckie and I have an Evo 6. Not had it long but was loving it until the balance shaft belt snapped :((previous owner had done the cam belt but not the balance shaft belt). I spent the money and got it fixed, I got some new pulleys and a clear cam cover, was running great until the adjuster bolts unwound and one got wedged in the cover and shredded half of the new belt. So back to square one again.
Now heres where I need help new belt on and timed up perfect, got fuel getting to the plugs and got a spark. It turns over and tries to fire but wont catch...
Does anyone have any ideas?
Thanks in advance
Beckie
8oyd
8oyd
devon
hello and welcome.....
it could have damaged the crank shaft position sensor, or some debry came from belt and could be logded in the teeth of the timing sprocket.
hope ya sort it!
Welcome along. Wow that's a he'll of a start to ownership.
Could be cam/crank pos sensor pull it out give a clean and back in or straight replace
evobex
Thanks for the warm welcome.
Its had a new set of pulleys since, new belt, new cam sensor and new crank sensor.
Its a mystery:confused:
8oyd
8oyd
devon
sounds like they have missd something if it still aint working.
who has been doing the work?
evobex
My other half hes a mechanic, everything is plugged in where it should be and has gone back as it was before when it was working. We have left the pluge out as they were soaked and the pistons were as well it couldnt be that could it??
C
CRABBY
Norfolk
Hi and Welcome!!
Where about you from in Norfolk. There appears to be a few of us up in this neck of the woods :)
Good luck with trying to sort you problem!
8oyd
8oyd
devon
could be something as simple as an earth if your getting a spark, could be many things
hope ya get it sorted
evo arm's m7960
evo arm's m7960
hello :O)
check the cam timing again and it may be i idea to do a compression check :O)
and if you can try some new plugs , plugs that have been soaked in fuel dont like to work properly even when dry :O)
Phil74
Phil74
Hi & Welcome, jave you checked the bearing for your balance shaft as these spin/rotate 3-4 times faster than your engine and do wear quickly and this is why it is a good idea to use a balance shaft eliminator kit to remove it as these are a potential weak spot. Also when the balance shaft belt broke the timing belt could of jumped a tooth or a couple of teeth and cause some internal damage. Good idea to to do a compression check on it.
