KK is an 8 MR
evo 9's are L and M
Andy
evo 9's are L and M
Andy
You sure it's not an 8 dressed as a 9 ? as that would also explain the incorrect engine fitted but correct for an 8 dressed as a 9. Does the speedo on right say Lancer or Evolution ?
does it have 2 raised runners on the roof?
looks like the MR then, was it a private sale or from a dealer
If private you have less leverage then if it was a dealer. You would have grounds on the fact it was falsely advertised but would require a solicitor and a day in court if the person you bought it off gave no joy also how long have you had it.
It will be a nice car once you sorted I think you may have to take this one on the chin and hopefully learn to check more not everyone is honest mate or go.l the court route but it may cost you.. You have one of the better spec 8's. You must of liked the look of it ect to buy it so I would make it the best you can and enjoy it or sell it but will be at a loss so may as well keep it not a case of its dodgy it's just been advertised incorrectly as the engine and bits fitted are correct for what it really is.
But as it's an 8 it would be the correct engine that you are looking at so the millage will tally upto that engine. Also does the engine number on hpi and logbook match the one in the car this will also confirm it's the original engine as fitted to an 8
Best thing to do is get it booked in with either someone on here who knows them well and get them to give it a once over and they will give you a report. Then from that report you can decide what you want to do.
Oil will be fine as long as it's good quality. I'd put in some ngk 8brs plugs in there gaped at 0.55mm. Then if still miss firing take it to some one than can check the map and fueling.
