Need help big time - PLEASE ASAP
evomon
Need help big time, I drained the ayc fluid by the diff by mistake...can I buy the oil/fluid off the shelf? If so what type is it and how much do I need? Can I just put straight back in?:confused:
jamie@evotune
Co. Durham
If its just the clutch bath you have drained its just a simple refill to the correct level you can use Dexron III atf and you will need a 1 liter bottle.
The filler plug is up the rear of the diff just where the ayc pipes go into the diff
evomon
I think it is, it's the drain plug by the diff drain plug...is that the clutch bath?
Thanks for the quick response mate
