more bottom end probs help !!!!!!!!!!!
matt0785
right guys got the engine stripped and a set of standard size acl con rod bearings tried to fit them today and they seem to be to thick fitted them to the car all torqued correctly but when there all torqued up the engine is very tight to turn by hand
is this normal or do i have something to worry about does anybody have a guide to fitting the bearings just to make sure i havent done anything wrong as the shells i took out didnt have any notched on any of the corners but the acl race bearings have a small notch on one of the corners is there a specific way this needs to be fitted
