T
tnofear666
- doncaster uk
I own a evo 3 and im having a few issues and could do with some advice.
on cold start it runs at 2000 rpm then once its warmed up it idles fine but cuts out at junctions. Not every time but at least 3 times a day..
also it keeps revvin itself from 1000 to 1500 and back again and so on, not always but from time to time. when it last did it i pulled a few plugs off and when i pulled the idle control valve plug there was no change. Iv removed and cleaned and tested it and its ok.. could i be right in thinking its a ecu problem? is it possible to test somehow? thanks in advance
