How can I fix under steer?
Waffle
Waffle
Cork, ireland
Obviously I can just drive slower :p
So far I've put in coil overs and poly bushed the front.
What else can I do?
Marty.H
Norwich
How have the coil overs been setup and what tyres you running. Also at what speeds you getting understeer as you must be pushing it hard
Better rubber or more throttle oversteer is king
andyw08
andyw08
skelmersdale lancashire
My car was under steering when my ayc wasnt working but didnt have any lights on the dash! Only found out when i had to bleed it because i had to do the clutch
Andy6
Andy6
Liverpool
Agreed, need to get the coil overs set up, try stiffening up to back in the mean time
