OutlawIV
Hi guys, well I just got my new Turbosmart Dual Port Valve and I installed it today but I've noticed the car started stalling and running rich.
Can someone help me sort this out? Because I already run with this problem with an HKS SSQVIII and I finally solved it reusing my oem bov even not having to recirculate my car was running pretty good and with no idle, running rich, backfiring whatsoever.
So what I want to know is if someone can help me setting it up to try avoid those problem or at least reducing them to the minimum?
My car is stock IV, hasnt been tuned or mapped but runs 1.3bar.
The loosen the spring the better? Because Im trying on the hard side and Im getting the problems I've mentioned.
I have it 50/50 Ventilated/Recirc
Thank you very much
Thank you very much
