Heat Management
grant620
grant620
Somerset, UK
Hi Guys,
We are now a stockist for Nimbus Heat Management / Shielding.
Most of you will have seen this shielding in one form or another.
Nimbus Lite is a revolutionary heat shield material. The embossed aluminium surface of Nimbus Lite gives a highly efficient thermal barrier and its unique construction provides the designer with exceptional mechanical strength without the penalty of increasing the weight plus the ability to accommodate complex forming applications.
Benefits of Nimbus Lite:
• Thermally efficient
• Fully recyclable
• Low Weight
• Ease of forming / shaping
• Low Cost
Single aluminium sheet, double embossed
• Product thickness 3.6mm
Available in these "sheet" sizes:
1000mm X 900mm - £109.00
900mm X 500mm - £57.00
500mm X 450mm - £28.00
Nimbus GII is a revolutionary heat shield material. Its double layer of aluminium structure gives a highly efficient thermal barrier coupled with effective acoustic damping characteristics. Furthermore, with its unique construction it provides the designer with the exceptional mechanical strength without the penalty of increased weight, and the ability to accommodate complex forming applications.
Benefits of Nimbus GII:
• Acoustically damped
• Fully recyclable
• Low Weight
• Ease of forming / Shaping
Double layer aluminium sheet, double formed
• Product thickness 5.25mm
1230mm X 1200mm - £195.00
1200mm X 615mm - £103.00
615mm X 600mm - £51.00
DEI "BLACK" Heat Wrap - 1000 deg C
Also available is the excellent DEI Heat Wrap for wrapping exhausts, manifolds, intake pipes, etc.
Wrapping exhaust and manifolds is an important first step in controlling exhaust temperatures and reducing under bonnet temperatures. By improving exhaust scavenging, intake temperatures are reduced which gives an overall improvement in performance and horsepower.
Constructed from a fiberglass composite material which withstands direct heat over 1000°C DEI "BLACK" Heat Wrap is as good as it gets!
Available in the following sizes:
1" Wide x 50ft Long - £53.00
2" Wide x 50ft Long - £85.00
1" Wide x 15ft Long - £15.50
2" Wide x 15ft Long - £24.50
