Have spark and fuel
Sprout dj
Sprout dj
I have spark and my plugs are wet but she still won't fire over ? I can't hear the fuel pump kick it at all and there's enough compression ?
What else would you try guys ?
ad-p
ad-p
I had a similar problem to this after the snow hit a while back, I cleaned up my maf, all earths, battery terminals and battery leads at both ends and changed all the vacuum lines and it's been fine since :D hopefully yours is just the same mate
Plugs are wet? I would try dry them off or pop new ones in that wont be helping, crank sensor is a likely suspect.
JakeMac
JakeMac
Bournemouth
I'd remove the rail with injectors to make sure 100% you have fuel being injected. If you have spark, fuel and the engine timing is correct with good compression then id start looking at sensors/ecu. I know the ecu on early evo's are prone to the capacitors leaking and destroying the circuit board but thats a worst case senario, keep us updated with how you get on and good luck. If you were closer I'd come give you a hand :)
Sprout dj
Sprout dj
Cheers jakemac It's going into the workshop tonight So hopefully I can let you all know what's up with her :)
