have problem with evo 4
G
gcas
started my evo 4 up one morning and it sounded really rough, waited for it too warm up, started too drive and had a whine/rattle like ball bearings. have so far to date changed the cam belt, fan belt tensioner (as it was seized), fan belt idle pully, water pump, turbo and still have the same noise. can anybody give me any ideas?
Batz
Batz
Mabey try taking the aux belt of and start it up that will tell you if it's out to do with the alternator or pulleys
G
gcas
thanks for the advice. have took the belt off and still have the same noise. if it is the crank would it be worth doing?
If it's the crank on a 4 the only thing to do is scrap the engine and get a later one V onwards, crank walk is a serious problem with the IV block. Dump the oil and check for swarf in it,
Now now Craig. Stop the scare mungering. They are known for crank walk but don't have a major problem...
Op- possible tappets. Take rocker cover off and check
If a crank goes for a wander its a major problem is what I mean lol. Tappets will jus be a consistent tapping noise not bag of nails unless its sticking
G
gcas
confusing, I looked at a couple of video's about 'crank walk' on evo 4, but the sound is not the same as the ones on the video's I have watched , got some money to spend to try fix it but I also have the choice to by an evo 5, 43k miles for £6000, I have known the person selling the car for 7 years, which will be be better expense wise? evo 4 or 5?
If you have the money for a 5 then I'd get newer engine and forge it for half the cost. Then you'll have piece of mind of a new engine :)
Spring Loaded Suspension
Just wandering if its anything to do with your clutch as this can make your motor sound like a bag of spanners. The clutch springs come loss and rattle around.
Is it any better when putting your foot on the clutch.!
Tim
G
gcas
sill trying out find problem, now sounds like a lawnmower. have been told it may be the cams. trying to load a video, will hopefully have it on soon.
