fuel gauge
McFall1984
McFall1984
bought my evo 4 there few weeks back
previous owner told me from it was converted to MPH the fuel gauge never read right
once it hits quarter full its empty
says its a common fault in Evo's once converted?
would a set of clocks fix this? maybe a new float/sender?
I would have said the float/sender is more the culprit not heard of a conversion messing up the fuel readings before, pull the float out and make sure it's got full range of movement easilyif it's slightly sticky that will be your prob
McFall1984
McFall1984
tank under the rear bench?
never worked on a evo before but im willing to learn
How on earth can converting kph to mph affect the fuel gauge!? And it's certainly not common. The bloke knows nothing ....
Yes the tank is under rear bench. You will find 2 inspection hatches as it's a saddle bag type tank because of the prop...
McFall1984
McFall1984
i was thinkin myself how on earth could that happen
then i was thinkin maybe someone bought the lockwood dials an he maybe removed the needle an didnt put it back on right?
im not sure
but what i do know is that the light comes on at just over quarter full an the car dies at 1 nick under the quarter mark
McFall1984
McFall1984
ok i got the rear bench off, an found 2 black plates
the ones behind the drivers seat is the 1 i want yea?
i got 1 white plug i take thats the sensor?
question is do i need to remove the small nuts to get all out? or is the plug enough?
No it's the plate behind passenger seat unless you have a lhd
McFall1984
McFall1984
sorry should have updated
got the sender out an all looks well
i unplugged the plug an the gauge dropped but not completely an the light stayed on
unplugged the other plug from behind the driver seat an the light just went off an the gauge red just under half way between quarter an empty
do i have to drop the tank out an sort this out? i take it theres another sender under the other flap?
