Front camber
Hi all
Not had geo done as the car doesn't run just yet but just wondering what camber people are running on the front. Got the top mounts set as far as they go and there is still a slight degree of negative camber. There is a camber set up on the bottom of the shocks so will double check them as well.
Will get them properly set up once its all up and running. Just asking out of interest. :)
Matt
mlau1294
mlau1294
-2.0 to -2.5 on the front, zero toe; -1.5 on the rear, with 1 degree toe-in should be a good fast road set-up...
Hi all
Not had geo done as the car doesn't run just yet but just wondering what camber people are running on the front. Got the top mounts set as far as they go and there is still a slight bit of positive camber. There is a camber set up on the bottom of the shocks so will double check them as well.
Matt
