C
cherryredbenj11
As above is it hard to fit a boost controller? Is it a specialist job or could i do it myself. Has anyone got a step by step guide.
That was my next question, is fitting a 3 port just the same as an electronic boost controller. Is the only different that the 3 port has to be manually adjusted?is an easy job but why don't you save yourself ££ and fit a 3 port?
The 3 port is a direct replacement for the standard one but then adjustments are made with in the ecu itself
