fitting elec boost controller? evo 6
  • Thread starter cherryredbenj11
  • Start date
C
cherryredbenj11
As above is it hard to fit a boost controller? Is it a specialist job or could i do it myself. Has anyone got a step by step guide.
Peace of cake. Pipe out of turbo nipple into controller and out of controller into wastegate. 2 wires on solenoid connect to 2 wires from controller inside car. Controller wires up to stereo wires mount it all job done
Bristol
is an easy job but why don't you save yourself ££ and fit a 3 port?
C
cherryredbenj11
That was my next question, is fitting a 3 port just the same as an electronic boost controller. Is the only different that the 3 port has to be manually adjusted?
Wheres the best well known place to buy a 3 port?
C
cherryredbenj11
The 3 port is a direct replacement for the standard one but then adjustments are made with in the ecu itself
can i fit a 3 port for a while before i get it mapped?
C
cherryredbenj11
I know the walbro 255 is needed for the map aswell, will it harm the car if i fit this a while before the map?
